Globally select detail lines
    Is there a way/add-on that selects all detail lines of a certain type so they can be swapped for a different type?
    Select all instances does not work with detail lines...
    Brett Harris
    BIM Manager
    Erskine Dredge & Associates Architects Inc.
    Yes and No....Case Design has an add-in that can do this...but it doesn't work when lines are grouped.
    The free version lets you select one line types at a time....the subscription version lets you select multiple line types.
