Redundant room
    Redundant room
    Hello there, i hope you will have sunny day as i have
    I got problem which i cant solve..
    You should separate the regions, delete the extra Rooms, or move them into different regions. - revit says
    When use separation lines it doesnt help, says that lines are overlapping, but what should i do? give me advice please ;]
    You probably accidently copied and pasted your Room to the same place. Go to a Room Schedule (or create one), right click the room that says "Redundant Room" and select Show. Now check if you need it, and other wise delete it.
      Edited:
      By creating schedule, by selecting row ( redundant room) and clicking delete, i simply did it. And again by learning something new that seemed impossible, i almost ******* myself from happiness.
      bangobeat
      Senior Member
        Originally posted by bangobeat View Post
        Edited:
        when i click show.. revit says no good view could be found
        Right, that figures. And what if you simply delete it? What happens then?
          Problem solved, i love you mdradvies.
            Not a problem...
              We all love Martijn, hes the best :thumbsup:
              -Alex Cunningham
