Warning Problem
    Warning Problem
    I am using the Architectural package so why am I receiving this warning and how do I get rid of it?
    Help!!
    Patrick
    DO you have an MEP central model linked in? it just happens, if THEY have that warning. Dont sweat it, doesnt seem to have any performance hindrances in RAC.
      Nothing has been attached which is why I am surprised with the warning.
        Was your template created from a project that ever had an MEP file linked to it? A lot of warnigns tend to stick around long after... Vis a Vis gbXML export warnings....
        EDIT: And again, i wouldnt worry about it...
          Patrick, do you have any plumbing fixtures in your project that come from MEP libraries? plumbing fixtures with connectors? Have you tried replacing those fixtures with simple fixtures from the architectural content?
            The plumbing fixtures were of the new type used with connectors. I was afraid this would be the problem but one would think Autodesk would have solved this problem.
