This may be a ridiculously simple question.
I have previously not used wall sweeps on edited profiles.
The wall sweep only stays at the point where the wall is horizontal and stops where the profile is edited.
I can only surmise that Revit still sees the wall as un-edited and the edit is merely visual, therefore if the wall portion is "not visible" the wall sweep will also not be visible.
Alternately, would you create angled/sloped walls so that the sweep remains at the top and is angled? That seems like way too much work to get the desired effect.
Are there any workarounds?
Is this typical?
image link:
2013-04-01_1540 - GenreNomad's library
image is also attached.
Thank you,
-Mark
Is this typical?
image link:
Thank you,
-Mark
