Sheet Name Label Problem
    Can anyone help me with my titleblock.
    At the moment I have a sheet name label in my titleblock.
    Due to the format of how we title drawings we have two lines. For example :
    First Floor
    Proposed Ventilation Services
    The problem I've got is getting the label on 2 lines as above. I have tried to copy the label down in the family but this just repeats the words from the top label.
    So what I've ended up doing is stretching the top label so that it fits 2 lines and then using the space bar until the text drops to the line below.
    This isn't the correct method and it leaves the sheet names in the properties browser looking something like this
    949/M1 First Floor Ventilation Services
    So can anyone tell me how to get the sheet name to form 2 lines but not look ridiculous?
    Domsib
    Revit MEP - 1 Day at a time...
    Here's a thread on it. Haven't read it, though.
    Dan
      The only way to do it without the spacebar is to make the label in the titleblock short enough to say 'First Floor' and then wrap. Then to have options, youd need a bunch of parameters for turning on variations. In my humble opinion its totally not worth that OR the space bar. Just call uit "First Floor- Proposed Ventilation Services" and call it a day.
        It is probably worth just changing your format so it is on one line as Aaron suggests. I will often question trying to match old standards if it gets in the way of productivity and resists how Revit wants to behave, especially if its something subjective.
        `Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for'
        Socrates
          I tried the Ctrl+Enter trick yesterday (2013) and it worked fine.
          chad
            On a sheet title? Im in 2013 (WU2) right now and it doesnt work.
              apparently I can't read and need a vacation... I did it in a view title, not the sheet title. :hide:
              chad
                Interesting ... with the clarification you've given me an idea to try next week (assuming I remember) - thanks!
                  I think you have to do it from the properties not in the field itself to have it work.
                  Sent from my Transformer Prime TF201 using Tapatalk 2
                    Tried both, no joy.
