2012 Missing Templates Content
    Seem to be missing the usual "Annotation" and "Titleblocks" file from the ( Australian ) Metric Templates file. Looked everywhere but can't seem to find them.
    So no Generic Annotation, generic tags, etc.
    Anyone else get um.
    Mark Balsom
    what worekd for me was going through uninstall > ad or remove components and adding some other libraries.
    Or else uninstall and reinstall the australian libraries this way
    Hope this helps.,
    Geert
    Geert Vennix, architecte
    www.geertvennix.eu
      Man 2012 is having a lot of problems with their downloading.
      -Alex Cunningham
        Just to bump this along.
        Did any Aussie or Kiwi get the two files Annotation and Titleblocks in there metric templates download ?
        I have installed 2012 on 4 machines and neither got them. Last night I downloaded the New Zealand and French Content to check, the New Zealand didn't have it and the French did. Can anyone confirm either American,Dutch etc... if they exist in their metric templates folder.
        Mark Balsom
          I got the metric templates Annotation and Titleblocks in my NA download.
          Chad Koscinski | Architect
            Thanks Chad, I will download your content and rip them out of there.
            Mark Balsom
              Downloaded the US metric content and here is comparison of the Template Folder between Aust & NZ template folder and US template folder, both now called English.
              Be warned Australia and New Zealand users check your template folder (now called English)
              I installed in two different locations and 4 different machines and got the same results with missing templates.
              Mark Balsom
                Wow, that is a hell of a difference. You're missing a bit more than the annotations and titleblocks folders
                  Yep just a bit..... I always thought it looked totally lite on, but with the new file naming and custom paths to locations I was a bit confused and thought the missing stuff was else where, but after a check around I knew something was amiss.
                  Mark Balsom
                    Could someone upload these templates because mine is with default and I dont know if that why everytime I lift a wall It says display error...could someone help me with that pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
