    Hi pals.
    try to set revit scale to 1:333.33 but Revit ask for "enter an integer".
    how to do it?
    thanks.
    You don't. Revit will only take an integer.
    Dan
      Try 3:1000?
      Adam Hutchinson
      Engineer in Training
      Integrus Architecture, P.S.
        I doubt that scale exists on a scale rule... And as Dan mentionned, you won't be able to put a decimal in the scale. What is is intended for?
        Alexandre Cantin
          the scale exust, is widely used in civil.
            Not often...I never used it in the 12 years I worked Civil....and never used it for a highway I worked on either....
            But to need to use this in Revit? I think your using the wrong program and should be using Civil 3D...unless your trying to reference the Civil drawings on your plans? If that is the case we usually just bring in a jpg (since PDF's don't frickin work in Revit) of their plan on one of our sheets and a FOR REFERENCE ONLY text added...
