Phasing Takoff
    Phasing Takoff
    Hi, I'm trying to compute the removal and execution of new plaster in a project with Revit 2013, but I can not set the filter "phase" in my schedule, in order to divide the two groups (yellow (demolition) and red (new execution)) .
    I created a new parameter in the parameter group of the type "phase" called "remove only" and then assigning the parameter type "Yes / No". Then I tried to write both the phase filter (Transformation, in my case) that the same phase (Intervention) in the filter field properties of the computation, but to no avail. What's wrong?
    What I want to achieve are separate tables for the plaster to remove and what to do, now united under the phase (Intervention).
    Thanks in advance for your cooperation.
    Mauro
    The schedules are phase sensitive. You cannot combine elements from multiple phases into a single schedule. Create a schedule for each phase and set them next to each other in the sheet.Phase.PNG
