gross building area
    gross building area
    o.k. i have tried looking for my answer on past posts no luck, so here goes, all i want is a simple gross area calculation for a simple minded building. i have used area calculation it wants to give me the area inside the walls, obviously not gross area, i can't find any relief in properties. this is a very good example of a program that is at times completely non intuitive. can someone please show me the error of my ways.
    Look at Area Plans. View>New>Area Plan. You can use the exterior surface of the building as the boundary, and this method allows you to "sketch" or change the boundary for the area calculation.
    Area Plans - WikiHelp
    Scott D Davis
    Sr. AEC Technical Specialist
    Autodesk, Inc.
    http://bit.ly/aboutsdd
      I always use sketch....auto never seems to work for me...
        It seems like I may be one of the few users fortunate enough to have good luck with auto generated area boundaries. [provided I'm not doing BOMA calculations.]
        Bear | Chicago, IL
          o.k. Scott i click the view tab (immediately i don't know what to do, i can't find "New" to click.) I read all the wiki help, to no avail. I click area schedule no help.
          i click rentabel area, how do i see gross area?????
            what do you clck before sketching??
              Hi Tom
              See images
              Mark Balsom
                Thanks a million, I'll try it asap, and i will let you know....
                  ok, mark i must be getting closer, but where is the number??? i can't find it...
                    I assume by number you mean Area Tag. Once again see image. When you select Area Tag it will probably ask you to load one if not already loaded, it is usally found in your OOTB library folder under Annotations/Tags/Architectural/Area Tag
                    Mark Balsom
