Wall profile with chamfers
    Guys,
    Is it possible to create a wall profile that has edge chamfers/fillets already built into it?
    Originally posted by JasonWallis View Post
    Guys,
    Yep, in the "Edit Structure" section of defining a wall, you have to have the buildup preview in section view, then the "modify" button becomes active and you can define sweeps. It might not have the flexibility you require though (in that, I recall, you can only define vertical sweeps & reveals, and not have them behave to a pattern)
      Thanks Snowy, I will check that out.
