When I add a revision to a project, how do I get it to appear in my revision schedule?All the parameters in the schedule are set up and I am filling out the information in the project. But it wont appear in the schedule in the project.
Revision Schedules
So far, you have just defined the revision, but if I understand correctly, you have not tagged any design change that corresponds to that revision. Make the first revision cloud on a view, then tag the cloud, assigning a revision number to that cloud, and then, that revision will show up on the sheet where that view is shown.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
As a side note, if you add a revision cloud to a view that can be referenced on multiple sheets (Legend View), the Revision Schedule will not pick up the Revision. Also, you can't add a revision cloud directly on a Schedule View. For this reason, we have adopted the practice of adding revision clouds to the Sheets, rather than placing them on the Views.
I'm a Structural Consultant that is working on a project with an Architect that is out-of-house. I also suspect that this Architect is not comfortable...July 27, 2015, 04:14 PM
Hi all new to the forum
Having a problem with revision clouds, say I have revision 1 on sheet s1 and revision 1 and 2 on sheet s2
when...-
November 2, 2016, 09:05 PM -
In my company, we describe every revision stage from A to ... something.
I found that in revit , there's some label description only for CURRENT...May 25, 2012, 03:51 AM -
Can anyone advise me on revision schedules. I've added one to our title sheet which consists of a revision number, a date and a description.
...August 14, 2012, 10:22 AM -
Is it possible to make a revision schedule in a project? I already have one on my titleblock, but I want to create a new one in my project just for informational...April 9, 2012, 04:59 PM
Monumetric Footer In-screen
