Curtain wall mullions join
    Hello,
    Is it possible to edit the join of one entire curtian wall grid line, instead of selecting every mullion one by one and select "break at join"?
    How do you guys quickly control you mullion joins? not one by one I hope
    thanks!
    Boris
    Normally I tend to make the Overall changes in the CW's type properties - Either Horizontal or Vertical Override
    then do the individual touch up on a junction by junction basis
    Dwane
      Select a mullion, then right-click / Select Mullions / On Gridline, and choose Break at Join (or Make Continuous) on the ribbon.
      Take a moment to explore all the right-click Select options that have to do with curtainwalls - they make it easy to do a lot of the editing.
      Daniel Friesen
