Schedule Count Question
    I am creating a schedule in Revit 2013 Architecture, I have placed multiples of the same item (lets say A01). When I created a schedule and added the "count" field to give the amount of A01.
    The problem is the schedule is listing A01 five times in five different rows instead of showing A01 in one row with a count of five.
    You should sort the schedule by "type name" (if A01 is a type name) and then uncheck the "itemize every instance" at the bottom end.
    Alexandre Cantin
      Yep that was it, thank you very much.
