worksharing monitor issue
    see attached image, don't know how to get rid of that pending editing requests, and don't know what causing it as you can see "To" is empty, perhaps the only way out is everyone recreate local files?!
    Is someone's User Name under options blank? If you click on the Editing Requests button next to the Workets panel (bottom of window) you can retract editing requests.
      thanks MPwuzhere, it's possible that someone's User Name under options blank, but "Retreat" button is greyed out, well, i even cannot fix it by recreating local!?
      well, i'll try to create local w/ "empty" user name to see what happens.
        well, you cannot make user name blank, and i even tried "recreate" central file w/o luck.
        seems i'm out of options, anyone?
          Have everyone exit their local links....open the central file but discard from central....save as central and recreate all the local files...
            no, didn't work.
            i have to recreate and also RENAME central ...
            don't know what causes such issue, anyone had similar issue before?
              Might have to delete the backup folder too...but sometimes renaming the file helps decrease file size too...
