[All Verticals] - Edit/open DWG shortcuts
    Applies to: - All Verticals
    New Feature / Problem:
    Would like to be able to open a DWG / launch ACAD from within Revit.
    Because it can be quite time-consuming to launch ACAD and then hunt down the linked DWG buried deep in some folder looking for a file with a file name you can't quite remember.
    Workflow:
    Could be as simple as right click on a linked DWG in Revit and launch ACAD / open the linked DWG.
    Could also be buttons in the link manager. Select linked DWG, push button and launch ACAD / open the linked DWG. Or right click on the DWG in the link manager, etc.
    Would be nice if Revit could also cue if a link has been changed and then incorporate the reload command. Rather like ACAD notices changed xref's and asks to reload.
    Benefits:
    Save time.
    A lot easier to code than adding a new rending engine or a dynamo player.
    Attachment comments:
    Do you agree with the above?? Use the "RATE THIS THREAD" tool at the top right corner to express you opinion.
