Applies to: - All Verticals
New Feature / Problem:
When you right click on an object, you can select all of instance, in view or in project, but you cannot currently select objects by any parameters set on any object.
A feature like this would help to select certain objects in a project, even if they are different categories or families, but only if htye have a common parameter.
Workflow:
Will help productivity.
Benefits:
Faster working through a project
Attachment comments:
Do you agree with the above?? Use the "RATE THIS THREAD" tool at the top right corner to express you opinion.
Workflow:
Benefits:
