[All Verticals] - Line cleanup in elevations
    Applies to: - All Verticals
    New Feature / Problem:
    In elevations, Automatic cleaning of the joint lines in elements in the same plane, with the same material
    This eliminates the tedious use of linework tool in elevations which btw not always work or you have to join geometry which is not alway desirable.
    Workflow:
    A button in the VG settings: "automatically clean joint lines" with options to clean only the coplanar faces with the same material or with any material, or the option for using a different linetype, color etc. instead of just making the joint line "invisible"
    Benefits:
    If you are not satisfied, You can always use the linework tool, but it would save a lot of time in big projects
    Attachment comments:
    Do you agree with the above?? Use the "RATE THIS THREAD" tool at the top right corner to express you opinion.
