[Revit Architecture] - place slab edge on slope-edited floor
This topic is closed.
    Applies to: - Revit Architecture
    New Feature / Problem:
    Ability to add slab edges to floors with slope edits.
    Currently, the workflow is the reverse--you must 1st add slab edges, and then edit the slope ( modify subelements/points, etc. ) of the slab.
    Let's say someone has spent a great deal of time editing points on a complex floor slab. Then the designer asks that a special slab-edge profile be added. It cannot be done.
    Workflow:
    Create point-edited slab. Add slab edges. Done.
    Benefits:
    Improved efficiency in adding slab edges. Lets point edits be done 1st, then slab edges added.
    Attachment comments:
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
    Yep, it should already be that way. Thanks for creating the wishlist item, Cliff. :thumbsup:
    Dan
