[Revit Structure] - Improve analytical model
    Applies to: - Revit Structure
    New Feature / Problem:
    1)Define the bottom release and top release of analytical walls.
    With analytical columns, you can define the top and bottom release to pinned, fixed, bending moment or user defined.
    With analytical walls, you cannot.
    2) Place point boundary conditions under a wall and floor.
    3) Place line boundary conditions partially under a wall or slab edge
    1) When you're making calculations with Robot(or other packages) you need to define this releases, so why not in Revit
    2) When there are piles under a wall, you would like to model these as a point support under a wall
    3) When a certain slab edge is not fully supported with a line boundary condition, you need to define it for a part
    Workflow:
    See above
    Benefits:
    Make the analytical model in Revit more complete.
    Attachment comments:
