[All Verticals] - Improve slab, add shapehandels
This topic is closed.
    Applies to: - All Verticals
    New Feature / Problem:
    Make shapehandles on slab in section to control position.
    When you're working in a section and you want to change the edge of the floor, you need to:
    -go to floorplan
    -select the slab
    -edit the sketch
    -zoom
    -use allign or move to change the floorsketch
    When you can use the shapehandle in section, it's only 1 action
    Workflow:
    See above
    Benefits:
    Saving time when modelling
    Attachment comments:
    Not for me...
    The slab is rarely the defining factor in size. Slab sizes are usually based on the walls (or other structural members) they rest on / that surround them. Therefor I'm ok with the current workflow of being forced to change slab size only in a view where I have a line of sight to the entire boundary. In plan view, constraints can be assigned to let the slab move with other elements they reference, and that's enough for me.
    Speed isn't everything... Accuracy is (and that's coming from a guy started using Revit cause I was too sloppy to work with Autocad)
