[Revit Structure] - Improve area reinforcement
This topic is closed.
    Applies to: - Revit Structure
    New Feature / Problem:
    1) Option to convert area reinforcement to structural rebar.
    2) When you use the area-reinforcement, with a certain width, revit is alligning the remaining space between the bars in the middle of the area-reinforcement. It would be fine, if you can control this.
    1) In an early stage, area reinforcement is usefull. But when you're working things out, more detailled, the functionality is not good enough. So then you've to use the structural rebar function.
    2) On building site, the rebar is made by mesh-sheet(or bars). If mesh-sheet, there will be a remaining space on the edges(not in the middle)
    Workflow:
    see above
    Benefits:
    improves reinforcement drawings in revit
    Attachment comments:
