[All Verticals] - Hard Returns in Keynote.txt
This topic is closed.
    Applies to: - All Verticals
    New Feature / Problem:
    Currently it´s not possible to add "hard returns"/"line breaks" in the keynote.txt file
    I´ve helped a handfull of architectural firms with the implementation of Revit over the years, and they have ALL refused to use the keynotes due to the lack of "hard returns"
    They all want their keynotes to be displayed by eg. wall layers
    110 mm Brick
    175 mm Insulation, U=0.34
    100 mm Precast concrete panels
    Paint type.....
    and NOT:
    110 mm Brick, 175 mm Insulation, U=0.34, 100 mm Precast concrete panels, Paint type.....
    Workflow:
    Adding keynotes to the project for documentation, while keeping the advantages of Revit and BIM.
    Benefits:
    Would be able to use keynotes, instead of some odd manual workarounds.
    Attachment comments:
