Useful every day (at least for me....:-)
    after Padlock's thread, here's another one, not really tricky but VERY useful.
    Consider it as a reminder:
    when it comes to put a number in a cell, you are allowed in Revit to put some formula:
    ex: if your input should be: "3.50" , try "=78.50-75.00". the result will be calculated.
    works also with * , / , + and thanks to Mr Alfredo, pi().:thumbsup:
    don't forget it! :wine:
    PS: works also with dimensions.
    Julien
    P. DAC
    I use this when I am making bolts and stuff. where my paramets are half the full size... I put in 2.6875"/2 =1.34375"
    dont have to do the math then.
    -Alex Cunningham
      I use metric, no math either. But I do use this on occasion, especially when adding different lengths in one.
        Originally posted by jbenoit44 View Post
        ... and thanks to Mr Alfredo, pi().:thumbsup:
        .. speaking of that, I'd like to share that after that thread in Augi about pi some months ago, the news spread in some blogs over the internet, such as in these: (including one in French):
        http://www.andekan.com/blog/2010/10/...nd-eat-it-too/
        http://autodesk-revit.blogspot.com/2...1_archive.html
        http://revitez.blogspot.com/2010/10/...rencontre.html
          Okay, I'm a noob and don't understand. If you need 3.5 why not just type 3.5. What does making it a formula give you?
          Dan
            Its more a case of using the formula instead of working it out with a calculator (ie: you dont know the result is 3.5)
            Alex Page
            RevitWorks Ltd
              Dzatto, just faster to play with only one keyboard at a time.
              Also, rounding numbers could be a problem sometimes.
              Julien
              P. DAC
                Oh okay. I was thinking you knew the answer already. lol
                Yeah, that makes sense. Just type the formula in there if you know it. Cool. I'll have to remember that.
                Dan
                • New User topics
                  From the sounds of it over at AUGI there is little or no chance that the Forum history is coming back prior to 2013. And there is some small validity...
                  December 10, 2010, 07:11 PM
                • Arithmetic
                  How to add / subtract / multiply / divide / etc. While the very basics can be found under the Operators group, what about something a bit more complicated?...
                  January 22, 2015, 09:46 AM
                • ? Family help
                  if my width and depth are equal to or greater than 31" it should equal this....how do i write this so revit can understand. also what kind of formula...
                  June 30, 2016, 06:57 PM
                • Formula editing
                  I have a nested component that I am trying to modify in this way:
                  If the LPD Option is checked, then all sizes for parameters L and M are...
                  October 27, 2011, 10:03 PM
