Floor tag: thickness ....finally
    here's a link to a post of the French section that I wanted to share with you. It deals with tags for floors and slabs.
    This way, you will have the thickness in a tag for floor in plan views without shared parameter and manual input. Tricky (a lot ) but functional.
    Image to see the result and family attached.
    Enjoy!
    Julien
    P. DAC
    Hi
    I am having troubles to see the tag on some of the plans.. The warning says: ''None of the created elements are visible in.. You may want to check active view, its paramenters, and visibility settings, as well as any Plan Regions and their settings.''
    I am pretty sure that needs to be something very easy, but I can't find out, what am I not doing right. Even though I have checked what it does say in the warning..
    Can somebody give me a hint?
    Thank you in advance!
      There are many reasons why an element may not be present in a view. Unfortunately you've just got to work through them.
      Check out this thread. There are many more than 33 reasons there now.
      http://www.revitforum.org/tutorials-...maybe-why.html
        Thank you! It is very helpful
          this family is very helpfull but i don't know how to tranfer the thickness slab to as parameter?
          Some one can be explant to me. pls. thank alot
