Angle tip
    Angle tip
    Hello.
    Some of You Folks had a problem with angled dimensions where 90, 180, 270 angle made some errors.
    I replaced angle by X/Y coordinate
    Frontend
    backend
    90, 180, 270, 360 angle will not harm You ever
    Cheers!
    edit
    I jumped in hastily, suspicious this wouldn't work with minus angle values... so just built my own.... and lo it works - so snark retracted!
    mind; it does (or can) break when the trig.'d controllers (my ox and oy) are forced into minus... so you might want to make offset a factor of Length
    :thumbsup:
    snowyweston
      I work as a Revit family creator and everytime I had family where was some kind of rotation I wondered how to handle it, and some time ago I found solution for this problem
      Cheers!
      Edit: I saw Your previous post. you can put any value That's why I used offset to solve negatives
      scissorhands
        Dammit, too quick to quip and not quick enough to edit!
        :hide:
          Yep, You're right It can be modified whatever You like, I just post how to prevent that errors by replacing angles to X/Y coordinates.
          I use variations of this solution depends on what I need to have
            Next thing you know you're gonna be looking into quaternions!
            Greg McDowell Jr
            about.me/GMcDowellJr
              For what purpose? So far I haven't have such a thing to make
              scissorhands
                Originally posted by GMcDowellJr View Post
                quaternions!
                I had to Google that one
                  English is not my native language, I had to Google it too.
                    hello
                    very intersting post (i had problems last week)
                    how would you create your family? for example i have 7 item to manage with radius would you multiplicate parameters(to drive the references lines) in the final family or to put these parameters in nested family in order in the final family there's only the radius ?
                    it will make parameters in the final(hosted?) family clearer?
                    Phil
                    PS : apologises, i think i'm invertig hosted and nested!! :/
                    Freelance WWTP/HVAC Designer
                    Revit 2019
