Curtain wall panel selection :)
    I just came across this and haven't seen it mentioned in too many places.
    It seems it makes a good tip for beginners
    If you select a panel in a curtain wall, and you want to avoid (tab/click selection for every panel in the same column or row of the panel you chose) then you can right click and select from the dropdown menu select panel > along vertical grid, horizontal grid, or on host
    THis will select the row of panel,
    the column of panels or
    all the panels in the system.
    Please let me know if any further clarification needed
    Hope this helps!
    Juan Carlos Moreno
    Sisley Cosmetics
    Never knew that. Sweet.
    Of course, I don't use curtain walls. But if I ever do...
    Dan
      well, when you get the 32 story lube shop with unitized rain screen curtain wall on four sides...call me
