Sketching a Scroll
    Sketching a Scroll
    I thought I would share this image I made, representing the concept used in creating a scroll shaped piece of equipment. The image is color coded so you can see the centers of the 3 arcs used. Make sure to check "Center Mark Visible" in the properties of each arc and use a length parameter to locate the center of the arcs off the xy axis.
    http://www.captiveaire.com/
    Commercial Kitchen Ventilation Systems
