I'm sure most of you know this little tip, but for the beginners her it goes.
When making a selection of multiple elements that are connected, say beams for example, you can hit the tab key and revit will cycle through some of the elements until it highlights the beams connected together. Then you can click and make the selection of those elements.
However say you have a group of beams that need to be selected and then another group of beams that need to be selected as well. How to go about it???
You can hover your mouse over the first set, hit the TAB key until it highlights the elements needed.
Click to select the elements
Hover over the second set of elements then hit TAB key again BUT BEFORE Clicking again hold the CTRL key and then click this will add to the selection the next set of elements.
Repeat as needed.
Hope this helps
Repeat as needed.
Hope this helps
