Drafting Cut Pattern Line Weights on Walls
    I just stumbled across this nice tip from the Revit Clinic. I was trying to change my cut pattern line weight for a wall after I had overridden the pattern.
    Anyway, here it is.
    Dan
    Hi Dan,
    I looked into this, tested it out, but it does not seem to be working. Were you able to actually change the line weight of the cut pattern successfully? Seems like a great tip, but I must be missing something...
      Originally posted by Jj Mac View Post
      Hi Dan,
      Yes, it worked for me. Did you override the cut pattern of the wall first? For some reason, you have to actually override the cut pattern, then change it in the VG. You can't just change it in VG.
      Also, I'm still in 2011. I haven't tried it in 2012 yet.
      Dan
