Revit Formulas for "everyday" usage
This is a sticky topic.
    I´ve been building a lot of parametric content in Revit, and always enjoy the power of using formulas to drive and control things. So here´s a few examples that I´ve collected over time, and also some VERY recent additions (New rounding functions in Revit 2012).
    The basic operators (add, subtract, multiply, ect.) have been left out on purpose, but feel free to add more useful formulas, that you use in your families :beer:
    Exponentiation
    X raised to the power of Y = X ^ Y
    E raised to an x power
    E is a mathematical constant that is approximately equal to 2.7. It is an irrational number, but if we truncate it to 20 decimals it would be 2.7182818284590452353.
    Revit usage = exp(x)
    Circles with pi π
    Usage in Revit = pi()
    Circumference = pi() * (Radius * 2)
    Circumference = pi() * Diameter
    Circle Area = pi() * Radius ^ 2
    Square Root
    Fixed value = sqrt(999)
    Parameter = sqrt(Width)
    Formula= sqrt(Width + Height)
    Logarithm
    The logarithm of a number to a given base is the exponent to which the base must be raised in order to produce that number. For example, the logarithm of 1000 to base 10 is 3, because three factors of 10 must be multiplied to yield a thousand: 10 × 10 × 10 equals 1000
    Revit usage = log(1000)
    Force yes/no parameters to be checked or unchecked
    Force checked = 1 < 2
    Force unchecked = 1 > 2
    Conditional statements
    Conditional statement uses this structure:
    IF (<condition>, <result-if-true>, <result-if-false>)
    Supported Conditional Operators
    < Less than
    > Greater than
    = Equal
    / Divide
    AND Both statements are true
    OR One of the statements is true
    NOT Statement is false
    Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters.
    Currently, <= and >= are not implemented. To express such a comparison, you can use a logical NOT. For example, a<=b can be entered as NOT(a>b)
    Simple IF Statement
    IF (Length < 900, <true>, <false>)
    Formula That Returns Strings
    IF (Length < 900, “Opening too narrow”, “Opening OK”)
    Using logical AND
    IF ( AND (x = 1 , y = 2), <true>, <false>)
    Returns <true> if both x=1 and y=2, else <false>
    Using logical OR
    IF ( OR ( x = 1 , y = 2 ) , <true>, <false>)
    Returns <true> if either x=1 or y=2, else <false>
    Nested IF statements
    IF ( Length < 500 , 100 , IF ( Length < 750 , 200 , IF ( Length < 1000 , 300 , 400 ) ) )
    Returns 100 if Length<500, 200 if Length<750, 300 if Length<1000 and 400 if Length>1000
    IF with Yes/No condition
    Length > 40
    Returns checked box (<true>) if Lenght > 40
    NOT with Yes/No condition
    not(Viz)
    Returns checked box (<true>) if Yes/No parameter "Viz" is unchecked, and returns unchecked box (<false>) if Yes/No parameter "Viz" is checked.
    IF AND OR Returning the greatest of three values
    Say you have these 3 length parameters, and want a fourth parameter to return the greates value/lenght of the 3:
    Length A
    Length B
    Length C
    Return Length (Returns the greatest of the three length parameters)
    Return Length = if(and(or(Length A > Length B, Length A = Length B), or(Length A > Length C, Length A = Length C)), Length A, if(and(or(Length B > Length A, Length B = Length A), or(Length B > Length C, Length B = Length C)), Length B, if(and(or(Length C > Length A, Length C = Length A), or(Length C > Length B, Length C = Length B)), Length C, 0 mm)))
    Credit to: Joe Zhou for this formula!
    Another option is to use an extra "Calc" parameter, which is a bit more clumsy but also way easier and more manageable for us mortals.
    Calc = if(Length A > Length B, Length A, Length B)
    Return Length = if(Calc > Length C, Calc, Length C)
    And a third option:
    Return Length = if(A > D, if(A > C, if(A > B, A, B), if(B > C, B, C)), if(B > D, if(B > C, B, C), if(C > D, C, D)))
    Credit to: Ekkonap who posted this on May 23rd 2011.
    Trigonometry for right triangles:
    Known: a+b
    c = sqrt(a ^ 2 + b ^ 2)
    A = atan(a / b)
    B = atan(b / a)
    Known: a+c
    b = sqrt(c ^ 2 - a ^ 2)
    A = asin(a / c)
    B = acos(a / c)
    Known: b+c
    a = sqrt(c ^ 2 - b ^ 2)
    A = acos(b / c)
    B = asin(b / c)
    Known: c + A
    a = c * sin(A)
    b = c * cos(A)
    B = 90° - A
    Known: c + B
    a = c * cos(B)
    b = c * sin(B)
    A = 90° - B
    Known: a + B
    b = a * tan(B)
    c = a / cos(B)
    A = 90° - B
    Known: b + A
    a = b * tan(A)
    c = b / cos(A)
    B = 90° - A
    Known: a + A
    b = a / tan(A)
    c = a / sin(A)
    B = 90° - A
    Known: b + B
    a = b / tan(B)
    c = b / sin(B)
    A = 90° - B
    Range of Values
    Given the following parameters:
    user_value:
    min_value:
    max_value:
    actual_value: = if (user_value < min_value, min_value, if (user_value > max_value, max_value, user_value))
    Specify a range of valid entries, with the min_value and max_value parameters; then, use the actual value if it is within the range; otherwise, use your minimum or maximum values.
    Credits: Alfredo Medina, who posted this on March 23rd 2011
    Circular Segments.
    Here's how to calculate the Segment length, the Chord Length, the Angle etc. (Image should speak for itself)
    Sample file posted here
    Inconsistent Units
    Theres a seperate post explaining this behavior here:
    Revit - Inconsistent Units and how to neutralize them.
    Round Function In Formulas - New in Revit 2012
    Values in formulas can be now rounded up or down. For example, when riser height is calculated, one needs the function “round” to find the appropriate value.
    ROUND(x)
    The round function returns a number rounded nearest to a whole number. It doesn’t take into consideration rounding direction (round up or down). If the number is (for example) from 24.5 to 24.9, the function rounds it to 25. If it is from 23.1 to 23.4, the function rounds it to 23.
    Examples:
    round ( 23.4) = 23
    Round ( 23.5) = 24
    Round ( 23.6) = 24
    Round (-23.4) = -23
    Round (-23.5) = -23
    Round (-23.6) = -24
    Syntax
    The syntax for the round function is: round( number)
    number is the number to round.
    ROUNDDOWN(x)
    “x” is a unitless value that should return the smallest integral value less than or equal to x.
    For example:
    rounddown ( 23.0) = 23
    rounddown ( 23.5) = 23
    rounddown ( 23.9) = 23
    rounddown (-23.0) = -23
    rounddown (-23.5) = -24
    rounddown (-23.9) = -24
    The syntax for the rounddown function is: rounddown (number)
    number is the number to round down.
    ROUNDUP(x)
    “x” is a unitless value that should return the largest integral value greater than or equal to x.
    For example:
    roundup ( 23.0) = 23
    roundup ( 23.5) = 24
    roundup ( 23.9) = 24
    roundup (-23.0) = -23
    roundup (-23.5) = -23
    roundup (-23.9) = -23
    The syntax for the roundup function is: roundup (number)
    number is the number to round up.
    Note that when numbers such as 23.5 are rounded, they can result in either 23 or 24. To produce a stable result, for all the .5 cases, we round to the larger integer. That means that 23.5 is rounded to 24, while -23.5 to -23
    Round to a number: (Credit to: Sander_Malschaert)
    number to round: X
    number to round to: Y
    (ROUND(X/Y))*Y
    rounding a parameter value to the nearest five would look like this:
    (ROUND(<parameter>/5))*5
    great post Klaus! thanks
    Julien
    P. DAC
      Geez! Munkholm and Aaron are going to be running for The Best Posts of the Month again!
      Excellent post! Very useful! We gotta love RFO!
        Speechless. At this rate, I'll never get a POTM nomination. lol
        Dan
          Wow! I hadn't yet seen a formula for "IF AND OR Returning the greatest of three values". This is a real tour do force!
          Scott Hopkins AIA LEED AP
          Peikert Group Architects
            I could of really used this list when I was making my gusset plates. Took me a week to figure it all out. Rep for you.
            -Alex Cunningham
              A little quirky timesaver as well, instead of:
              Parameter1 = Parameter2 *-1
              use
              Parameter1= -Parameter2
              Alex Page
              RevitWorks Ltd
                And it's worh to mention that any poligon can be splited in triangles and that any triangle can be split in 2 right triangles. Eaven the right triangle can be splited in others 2 right triangles. Then you can use Munkholm formulas colection when study a geometry that is virtualy splited to a granular level of of right triangles.Of course triangles can be everywhere on a geometry, depends on the elements you choose to form your triangle.
                  In all fairness, Joe Zhou came up with this genius formula!
                  My initial take at it used an extra "Calc" parameter, which is a bit more clumsy but also way easier and more manageable for us mortals.
                    Who would LOVE to see CONCATENATE from excel incorporated into Revit schedules???
