v0.75 RFO Ribbon Add-In - Downloads
    Howdy folks. To try and push this project forward, I made a few changes to what surrounds the app, not the APP itself. Krispys loading code and mechanism remains intact and unchanged.
    I decided to include a few additional DLL files, standardize its home and wrap it all into a nice pretty installer (NSIS) which allows you easily install/uninstall the add-in for the 2012 product line.
    Krispy, I think its best if we keep track by version, I picked .75 as I think we're probably three quarters of the way there. I will include additional suggestions I have in the appropriate forum. I envision three threads for each version :
    • vX.XX RFO Ribbon Add-In - Downloads (for consumption by gen_pop)
    • vX.XX RFO Ribbon Add-In - Source (for the tinkerers)
    • vX.XX RFO Ribbon Add-In - Feedback (questions, suggestions, general feedback)
    The directories for the APP were selected as follows:
    Main APP files reside here
    C:\Program Files\RFoRibbon
    AddIns are here
    C:\Program Files\RFoRibbon\Addins
    Copy of the "MASTER" addin file is plopped here
    C:\ProgramData\Autodesk\Revit\Addins\2012
    Few screen shots and the app itself :
    ps-check out the EULA =) .. I think you'll find it to be quite humorous.
    bim cad tech com
    Jose,thanks you are a legend. Up and running, nice and easy.
    Just a suggestion, if this thing gets much bigger is it possible to have a switch to disable selected addins, or is there a way we are able to disable the addin files
    Thanks again.
    Mark Balsom
      Excellent point, .. addins can still be added removed manually :
      open up C:\Program Files\RFoRibbon\RFO_Addins.xml and edit the tag to say enabled =false
      Code:
          <Vendor Id="BIMK">
            <Command Id="4a238aa1-d689-400c-9570-278354b01792" Enabled="[B]False[/B]" />
            <Command Id="250622e5-03f6-46e4-8460-b16c67eaac54" Enabled="[B]False[/B]" />
          </Vendor>
      .. or remove the lines all together.
      bim cad tech com
        Way to go Jose! Love the automatic installer, and it of course works like a charm. Thanks!
          Code:
              <Vendor Id="BIMK">
              </Vendor>
          Thanks mate, too easy....
          Mark Balsom
            Is this for 2012 only?
            btw: love the EULA!!! hahahahah :beer:
            -Alex Cunningham
              Alex,
              THANKS!
              Yes 2012, I mention as such in the blurb above .. =) ...
              I thought the EULA was quite humorous! Found it online and modified it slightly.
              bim cad tech com
                Wish I could use this, but my IT guy is being really lazy about upgrading our license server....
                  tsk tsk .. come on Carl .. step it up brother.
                  bim cad tech com
                    any luck to have the 2013 version.
