Kiwi codes family browser2013
    Hi friends. I use FB13. I like this add-in. It has many good functions, but I cann't do them. For example...
    1. "Replace selected family with new family even if it is not loaded in the current project".
    How I can do it? Family didn't replace
    My steps...
    2013-01-12_2001 - mixtaper's library
    2. "Drag and drop families from windows explorer onto tabs".
    How I can do it? Family didn't add in FB.
    My steps...
    2013-01-12_2005 - mixtaper's library
    HI Mixtaper.
    First of welcome to the Forum.
    1. Sorry this has changed since the tutorial video was made and I need to redo it. First select the family you want to swap. Then hold down the "Ctrl" Key while you drag/drop the new family into the Revit screen. FB will then swap the families.
    2. It looks as though this function is not working in the current build. I will look into that first thing on Monday Morning and get back to you when I have a fix for that.
    Regards
    Phillip Miller
    Kiwi Codes Solutions Ltd
    Makers of "Family Browser" and "Project Browser" for Revit.
      I tried hold down ctrl. Family replaced 3 times and after sometime I tried again. But in this time I added new famile ( no replace).
      If you need I can record video.
        mixtaper.
        I have updated Family Browser and:
        1. Removed the requirement to hold down the "ctrl" key to swap a family. Now all you need to do is select the family/families that you want to swap and then drag/drop a family (within the same category) to swap them out.
        2. I have fixed the drag and drop from windows explorer onto Family Browser.
        Right mouse click on Family Browser and go to -> About and then click on check for updates to get the link for the new version.
        Cheers
        Phillip
        Phillip Miller
          Second fix is good.
          But first, I don't know what I did wrong
          I tried on another computer, the same result
          2013-01-20_1604 - mixtaper's library
            And How i can delet one famaly from FB&
              Just remove the family from the folder using Windows explorer or similar and it will disappear from the Family Browser Tab.
              Phillip Miller
                Hi. How I can edit cataloge and save txt file in unicode or ANSI format? With UTF-8 I have problem in Russia
                  HI Mixtaper.
                  Good question. I will look into it for you.
                  In the future can you also post these questions on our support forum as I watch/get notifications of posts as they happen there, but I don't come to this forum as regularly. - Kiwicodes Support Forum/
                  Phillip Miller
