Can a class with interface run another class with interface?
    As I understand classes with IExternalCommand implemented are our entry points.
    Is it possible for one class such as to run another one after what it does.
    For example how can I make classA to run classB after itself?
    namespace name
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Rev it.Attributes.TransactionMode.Manual)]
    public class classA : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
    //code
    public class classB : IExternalCommand
    //code
    http://www.redhotbim.com
    http://www.revitkutuphanesi.com (in Turkish)
    I don´t get the point of doing it.
    It might just work, but it doesn´t seem logic.
    Why don´t you put both blocks of code inside classA ?
    What am I missing?
    Gonçalo Feio
      I do something like this all the time, but I create a void within the class, as feio suggests.
      Usually, I do this when I need to do the same thing to a group of objects. For example, find all families in the casework category. For each faimily, if there are types defined, Now_Do_This(). If there are not types defined, Now_Do_Something_Else(). (The example below does not do any looping)
      Code:
      namespace name
         //code
         Now_Do_This(with_this_string_variable);
         //more code
         Now_Do_Something_Else(family_name, element_id, param, number_of_things);
         return Result.Succeeded;
        }//result
       //inside classA, add this code to pass a string to your new code
       public void Now_Do_This(string with_this_string_variable)
          //do stuff with with_this_string_variable
        }//Now_Do_This
       //add this code to pass a string, an element id, a parameter and an integer
       // to your new code - the variable names do not have to match, i am showing
       // them as matching to show how it works
       public void Now_Do_Something_Else(string family_name, ElementId element_id, Parameter param, int number_of_things)
          //do stuff with the four variables
        }//Now_Do_Something_Else
       }//classA
      }//namespace
        Thank you very much.
