Anyone tried this? Im trying to change the workset id of a revit link type after it has been added using DMU...
The code work fine if I try this with Pipe just not RevitLinkType. It also works using pick command. Any ideas for workarounds to make this work?
The code I'm using...
Code:
var updater = new Updater(_app.ActiveAddInId); UpdaterRegistry.RegisterUpdater(updater); var filter = new ElementCategoryFilter(BuiltInCategory.OST_RvtLinks); UpdaterRegistry.AddTrigger(updater.GetUpdaterId(), filter, Element.GetChangeTypeElementAddition());
Code:
public void Execute(UpdaterData data) { Document doc = data.GetDocument(); foreach (ElementId addedElemId in data.GetAddedElementIds()) { if (doc.get_Element(addedElemId) is RevitLinkType) { var link = doc.get_Element(addedElemId) as RevitLinkType; var frm = new frmSelectRVTLinkType(link.Name); if (frm.ShowDialog() == DialogResult.OK) { Utils.SetWorksetVisibility(frm.LT.GetWorkset(), WorksetVisibility.Visible, false); Utils.SetElementWorkset(link, frm.LT.GetWorkset(), false); } } } }
Code:
public static void SetElementWorkset(Element element, Workset workset, bool useTrans) { if (element == null || workset == null) return; Transaction trans = null; if (useTrans) { trans = new Transaction(Document); trans.Start("SetElementWorkset"); } var param = element.get_Parameter("Workset"); if (param == null) return; if (param.AsInteger() == workset.Id.IntegerValue) return; param.Set(workset.Id.IntegerValue); if (useTrans) { trans.Commit(); } }
