Subscribing to Database Events - application.DocumentOpened
    I am following the Revit 2012 API WikiHelp Walkthrough code example for registering events.
    Code follows:
    public IExternalApplication.Result OnStartup(ControlledApplication application)
    try
    // Register event.
    application.DocumentOpened += new EventHandler
    <Autodesk.Revit.Events.DocumentOpenedEventArgs>(application_DocumentOpen ed);
    catch (Exception)
    return Autodesk.Revit.UI.Result.Failed;
    return Autodesk.Revit.UI.Result.Succeeded;
    I am receiving errors:
    'Autodesk.Revit.UI.UIControlledApplication' does not contain a definition for 'DocumentOpened' and no extension method 'DocumentOpened' accepting a first argument of type 'Autodesk.Revit.UI.UIControlledApplication' could be found (are you missing a using directive or an assembly reference?)
    The type or namespace name 'Events' does not exist in the namespace 'Autodesk.Revit' (are you missing an assembly reference?)
    What am I missing?
    And the answer is:
    application.ControlledApplication.DocumentOpened += new EventHandler
    <Autodesk.Revit.DB.Events.DocumentOpenedEventArgs> (application_DocumentOpened);
