APP - Batch Convert Content Utility
    Soo.. as promised and sorry for the delay, been quite busy. Give it a whirl, kick its tires, let me know if it helps you at all.
    http://blog.bimkicks.com/post/2011/0...h-Upgrade.aspx
    This is a little app I had put together some years back, it was meant to be a front end for the "Content Batch Upgrade Utility Tool" that ships on the REVIT disc.
    Since I delayed publishing longer than I should have Autodesk has also stepped up and published an upgrade utility now available from the labs(http://labs.autodesk.com/utilities/adn_plugins/).
    I would like to highlight a few differences from my app that in my opinion make it stand out :
    * Installation not required (runs from wherever you extract it)
    * Upgrade several file formats (rvt, rfa, rte - the labs version does as well)
    * Quickly select and remove Files and FOLDERs for conversion
    * Ability to inject CUSTOM journal commands to customize actions per file
    * Selection to delete REVIT generated "0001" files
    * Look cool while you're using it .. ;-)
    joseguia
    Senior Member
    bim cad tech com
    Thanks Jose looks cool, I'll give it a whirl.
    Mark Balsom
      Certainly going to try this
        Jose thanks for new toy great.
        Being API and Journal illiterate looks like it would be possible to run a journal command to open each family as-
        -Default 3D View
        -Front Left isometric
        -Shaded with Edges
        -Zoom to Fit
        -Save (save options)
        (Tick) regenerate if View/Sheet not up to Date
        This would give consistency in views in Family Browser and save me ton's of work.
        Question
        How do you write the routine, please. :hide:
        Mark Balsom
          Originally posted by mark b View Post
          -Default 3D View
          -Shaded with Edges
          -Zoom to Fit
          -Export view as image....?
          Would be cool for creating thumb views too
          Great App Jose! Thanks :beer:
            glad to be of assistance, ..
            mark, klaus, you could fire up the add-in command line utility I wrote (also on my blog and here ) and turn on FULL LOGGING under options, when you perform an action you can view the results, .. copy and paste into this app and go! It really is that simple, that's how I got the zoomfit portion.
            feel free to share snippets here if you find some that work for you, I will add them to the "Pre-Sets"
            bim cad tech com
              OK, sounds like a challange and somthing to do over the weekend. :thumbsup:
              Mark Balsom
