Approval & help needed
    Hi guys,
    First off: thanks to all that contributed with some great Addons...
    Now, here's the question:
    I've found three great apps with code floating around here:
    - Wall Join Allow/Disallow by API, created by Krispy5
    - Mirror parameters, created by Feio
    - Retrieve Filtered Elements by Nelson.
    Now, there's probably more to follow but would it be nice to put all of these under an RFO Addon? I know that starting 2012 you can create your own Ribbon Tabs (check out the Room/Window Area Addin), so this would be cool to create (and also a good excercise for us noobs).
    But, I don't want to do this without the author's concent. So anyone who posted a sample here on RFO, please respond...
    Oh, and also it would be nice if someone could give me some pointers on how to actually make that happen :hide: Cause I'm kind of in the dark on that one...
    I Think that is a great idea.
    I would be prepaird to add some of our free apps to it as well as add some other small apps that I have floating around in the back of my head
    Phillip Miller
    Kiwi Codes Solutions Ltd
    Makers of "Family Browser" and "Project Browser" for Revit.
      Cool, thanks!
      btw: already found the way to create a ribbon tab (read the manual).
        LOL. That sometimes helps. I haven't had a chance to look at that yet as I have been flat out finishing off an API program for a client.
        BTW we implemented custom ribbon Tabs in Revit 2010 and 2011 using GuyR's way which worked a treat. I'm sure the 2012 way though will be a little more integrated
        Phillip Miller
          No problem to include mine, I'll add my text align and a change text case one as well. Do you want images for the tool buttons?
          I too used guy's method to add a custom tab last year, i used the standard method this year.
          http://krispcad.blogspot.com/
            That would be great. I also PM'd Klaus for a bitmap from the Revitforum logo, so we can make this one big giant commercial
            That said, there's also the possibility to include a flyout explanation (like the tooltips you also find in native Revit commands in which I would like to give credit to the actual writer of the code. Does anyone have any experience with this?
              I have done some extended tooltips on our custom ribbon tab, see screenshot:
                Right, exactly like that. Care to share how you did this?
                  You just assign a "ToolTip" and "LongDescription" to the "ButtonData" object.
                    Hi Martijn, how are you going with this? Do you need any help? I had a few thoughts about how to achieve this.
