Naming Convention - System Families
This topic is closed.
This is a sticky topic.
    How should walls, floors, roofs, ceilings, etc. be named ?
    <Identifier>_<Category>_<Type>_<Descriptor>_<Siz e>
    <Identifier>
    #RFO (The "#" to sort on top)
    <Classification>
    The SfB-code requires different coding for different Wall Types:
    28 - Bearing
    22 - Interior, non bearing
    21 - Exterior, non bearing
    20 - Walls, not classified according to the above yet.
    etc. Is there something like this in the MasterFormat?
    <Type>
    If not the above I would do this using a type-format:
    Bea = Bearing (should we do the different kinds: Shear, Bearing, Combined?)
    Int = Interior
    Ext = Exterior
    Fin = Finish
    For instance:
    #RFO_21_Masonry_insulation_concrete (but then using MasterFormat)
    OR
    #RFO_Ext_Masonry_insulation_concrete
    <Descriptor>
    Product / Type
    <Size>
    Total construction width or breakdown into layers? For instance:
    #RFO_21_Masonry_insulation_concrete_300
    OR
    #RFO_21_Masonry_insulation_concrete_100_100_100
    Best Practises:
    Naming of layers always starting with exterior layer
    Naming of layers: also name Membrane or Air layers? I normally don't...
      We do it a bit difference
      "Exterior Cladding_Framing_Interior Lining"
      "Weatherboard_90T_Plasterboard", "Weatherboard_Cv-90T_Plasterboard"
      Easy to see what its clad in & what Framing Size the Walls are
      Easy to use to select it also - In Wall command just type "W"on keyboard & in the Properties Palette it goes straight to it
      Using any numerical sequence generally take a few more clicks to get to the right type
      Dwane
        Do you want to differentiate between for example "Basic Wall" and "Stacked Wall"?
        Sander Obdeijn
        Support Engineer
        ITANNEX [Autodesk Gold Partner]
        Personal Mailadres:
        [email protected]
        General Support Mailadres:
        [email protected]
          I don't really see the need for this, because they are differentiated in the Properties Pallette. But frankly for me this is easy: do NOT use stacked walls...
            Correct me if I am wrong too. Stacked Walls can't be Copy Monitored... at least not into RST.
            -Alex Cunningham
              I think we've tried every approach to date.
              What I've always hated about literal naming (as in stating physical attributes & performace) is how names can end up not tallying with their parameter/build up information... so we're presently employing a more "robotic" method :
              Int. Walls : P01, P02, P03...
              Ext. Walls : E01, E02, E03...
              Floors : F01, F02, F03...
              Roofs : R01, R02, R03...
              Ceilings : C01, C02, C03...
              and do the same with (most of) our loaded family types... windows get a "W", doors get a "D", etc...
              We then define their construction in our specification & with type-based "drawings".
              It makes things "feel" a bit counter-intuitive at first, but actually helps in the long run when relating our model to our design - and identifying/managing types.
              So far, it works us.
                Here´s how I´ve done it so far:
                <Type>_<TotalThickess>_<MainLayers>_<MainLayerThic kness>
                e.g.
                Ext_400_Brick-Insul-Conc_110-190-100
                or
                Int_120_Gyps-Insul-Gyps_25-70-25
                Secondary layers as membranes, airspaces etc. are always left out.
                For <Type> I´m using something like this:
                Base = Foundations
                Ext = Exterior walls
                Int = Interior walls
                Generic = One layer walls, floors, roofs etc. for the PD
                Roof = Roof
                Floor = Floor finishes
                Slab = Floor Slabs
                Site = For floors when used as the missing site tools
                And on top of that I have a huge list of abbreviations used the the layers...
                  Yep, this is also the way I do it, except I don't use an abbreviation for function, I use the SfB-codes (Ext = 21, Int = 22, Generic = 20, Floor = 23, etc)
                    Doubt that most people would cherish the SfB codings... but I´m game
                    On a more serious note: Do the MF have similar options ? (Or any other international ISO standard...?)
