David Light: Are you going to AU2011? Do you Vasari?
    If you have answered “yes” to both these questions, be sure to sign up for Matt Jezky & Zach Krons class entitled Autodesk® Project Vasari: Playing with Energetic Supermodels. Wow, what a title, the mind boggles!
    Class No. AB9660-L
    Class Description:
    In this hands-on lab, you will explore experimental tools and workflows using Autodesk Project Vasari. Project Vasari connects the parametric modelling capabilities of Autodesk Revit® with many of the analysis and simulation capabilities available in Autodesk Ecotect® Analysis and Autodesk Green Building Studio. You will also learn about and use new performance-based design tools available from Autodesk Labs. First, you will create a few parametric building models and simulations. Next, the class will cover more advanced topics, such as how to create automated feedback loops. You will explore workflows where changes you make to the model cause changes in the simulation results, which then drive changes back into the model. You will use both out-of-the-box tools and add-ons currently under development to create parametric building models that respond to environmental conditions through both automatic and semi-automatic feedback loops.
