Revit Kid: Revit Tip - Revit Foundation Walls Not Visible in View Error
    I was having a discussion with a friend and he asked about why he always gets this error when he is creating foundation walls:
    This error stems from the way a foundation wall's properties are defaulted:
    Notice the base constraint is actually your current level and the offset is set to -12'-0". Also, notice the top constraint is then set to your current level... So, basically, unless you change this defaulted properties setting EVERY TIME you select a foundation wall you WILL get this error...
    Kind of silly if you ask me..
    Posted by: Jeffrey A. Pinheiro, LEED AP at The Revit Kid.com!
