Revit Kid: Revit Tip - 10 Reasons Why You Can't See and Element
    Great little tip from earlier in the year. I thought I had posted this but turns out it was in my drafts...
    Top 10 Reasons You Can't See an Element in Revit
    1. Is the correct Workset being used?
    2. Is the view range set correctly to see the particular element?
    3. Is the object hosted on an incorrect surface like a floor instead of a ceiling?
    4. Is there a filter applied to the view that is causing the element to be hidden?
    5. Is the detail level of the view set correctly? Some families are set not to show at Coarse.
    Click here to see the remaining 5 reasons....
    Posted by: Jeffrey A. Pinheiro, LEED AP at The Revit Kid.com!
