RFO Blog: The Best Posts of the Month, September 2011
    Hi guys and gals, back again for yet another round of the Post of the Month elections! The Poll is published here, please feel free to give your votes at any time and acknowledge the effort the authors put in it...
    Sorry this is kind of late, my vacation with Mickey and friends stood between me and my laptop, so this had to wait...
    For everyone who doesn't have a clear remembrance of the original postings, here's a brief summary of them all:
    Nr 1: Rotate Generic Model in Place by Alfred Medina.
    This thread started with the question on how to rotate an in-place Generic Model from a horizontal to a vertical plane (in other words: rotate around the x-axis). Seemed like it couldn't be done because of the constraint to the workplane the geometry was created in. Alfredo provided an easy and effective solution: Group the geometry you wish to rotate after which this is possible.
    Nr 2: Organize Schedules by Steve Stafford.
    Long standing wishlisht item: the possibility to organise Schedules in the Project Browser. By default, Schedules are organised alfabetically, thus forcing people to either use unnecesary and/or confusing prefixes in their Schedule Names, or search for the proper Schedule in a bunch of unorganised Schedules...
    Steve came up with a solution to this which uses the possibility to disconnect the visible name of the schedule from it's actual name by using Group Headers instead of the actual Schedule Name.
    Nr 3. Reconstruction Phases & Rooms by mdradviesThe thread started with a question about the way Phases should be set up if you have a situation where you want to show Rooms from an Existing Phase in a next Phase (in this instance Phase Demolished). Mdradvies provided two possible solutions: one with the use of overlayed Views on Sheet (Room not actually being in the next Phase though) and one which deleted the Phase Demolished and used Phase Filters to set up the desired visual representation.
    Nr 4. Link ACAD Notes at Correct Scale by Steve Stafford
    The thread started with a question about importing standard drawing notes from autocad in Revit. The author had problems with scaling and sheet placement of the imported notes. Steve posted a thorough how-to for this, also adding some pointers and possible pitfalls.
    Nr 5. Rotate Generic Model in Place by Mr Spot
    The thread started with a question on how to rotate an In Place Generic Model over the x-axis (from Plan View to Elevation View). This issue was finally resolved in a few different ways (Pick New Host, Group and then rotate). In response to the whole discussion Mr Spot posted a generic solution to rotating a Non-Hosted Family which will work in probably any situation: make it workplane based and host it on a (named) Reference Plane. You can now rotate the Reference Plane and with that the entire family.
    Nr 6. Reconcile Hosting by Jrobker
    A post (and entire thread) worth reading for anyone who works with third-party MEP Consultants. The thread started with a question about an error occurring when an Architects model has new Ceilings. All ceiling based MEP objects will get unhosted. Most can be rehosted again, but some stay "Not Associated".
    In response to this, and the following discussion, Jrobker posted a complete list of all the "do's and don'ts" in collaborating with MEP consultants.
    Nr 7. 2d Symbols as Component by Alex Page
    The thread started with the question on how to create (2D) furniture in Revit. Alex provided a step-by-step tutorial on how to do this using the proper family templates. He also added the tip to create the 2D furniture on a refplane with a parametric offset to the Reference Level. This way, in plan view, elements with different heights will correctly obscure each other, even while they are just 2D.
    Nr 8. Association Work Plane by Alfredo Medina
    The thread started out with a constraints issue in a Door Family. Using the would break the link between the parameter and the nested families which needed to be swapped.
    Alfredo posted the correct workflow to do this and make the type swappable by parameter without breaking the link.
    Nr 9. Multi-category schedule by Gaby424
    Alfredo Medina started up the thread, asking the forum about the general useage of Multi-Category Schedules. It turned into a lively discussion which focussed on how to deal with the seemingly random availability of standard Out of the Box parameters, such as Volume, in a Multi Category Schedule. For the Volume, Gaby424 gave an easy but effective solution: using Multi Category Material Takeoffs.
    Nr. 10 Curtain Walls Not Joining by mdradvies
    The thread started with a question about joining two Curtain Walls. How to get a Curtain Wall join 2 glass panels correctly without a vertical mullion (glass with a clear butt joint).
    mdradvies responded with a way to use the vertical mullions to create a sealant between the two glass panels. Give the Mullion Profile the correct size and offset and use the ootb L-Corner Mullion as a template. It will joint the two panels together, much like common building practise for butt joints and still look good in Detail / Elevation / 3D.
    So, we yet again have some beautiful contributions worth voting for. Please cast your votes here...
  • RFO Blog: The Best Posts of the Month of September 2011 in Revitforum.org
    1) Post #30573 by by Steve Stafford in Thread: Organize Schedules
    2) Post #30920 by Alex Page in Thread: Can I Make 2d symbols Furniture...
    October 30, 2011, 05:15 PM
  • Please Vote for the Best 3 Posts of the Month of August 2011
    From this list of the 10 most nominated posts, (sorted by number of nominations, most nominated on top) please vote, above, for 3, that in your opinion,...
    Post #25265 by FBlome in Thread: Worksets and DropBox - how to do it without getting yourself in deep doodoo
    20.83%
    5
    Post #27089 by Gordon Price in Thread: Working Views and Annotation Views - display of view callouts
    16.67%
    4
    Post #26725 by mark b in Thread: Sloping parapet?
    16.67%
    4
    Post #27213 by openrevit in Thread: energy setting - building construction
    8.33%
    2
    Post #27090 by Scott D Davis in Thread: My favorite thing about Revit (not... caution rant)
    0.00%
    0
    Post #26559 by mdradvies in Thread: Using Parameters and Schedules for Phase hatches
    12.50%
    3
    Post #24981 by Munkholm in Thread: Stone Section Detail Component
    8.33%
    2
    Post #28242 by Alfredo Medina in Thread: Wall Section strategy...
    8.33%
    2
    Post #28240 by Munkholm in Thread: project template upgrading
    8.33%
    2
    Post #27860 by mdradvies in Thread: A Schedule Question...How Do I...
    0.00%
    0
    September 15, 2011, 03:07 AM
  • RFO Blog: RFO Post of the Month Nominees
    So I recently volunteered to write a blog post on the RevitForum Post of the Month nominees. Since this is the initial post I have been thinking about...
    August 18, 2011, 01:00 AM
  • Please Vote for the Best 3 Posts of the Month of July 2011
    Post #22648 by Scott Hopkins in Thread: View Title Secrets Revealed
    25.71%
    9
    Post #23997 by mdradvies in Thread: Push parameters in the project environment
    17.14%
    6
    Post #24654 by Steve_Stafford in Thread: (Faking) Property Lines in Sections
    20.00%
    7
    Post #24728 by Mr Spot in Thread: Grids shown on different levels tip
    5.71%
    2
    Post #22670 by CBukowski in Thread: Detail Callouts are not editable
    5.71%
    2
    Post #23540 by gaby424 in Thread: Export Materials in fbx to 3dsMax problems
    0.00%
    0
    Post #22905 by sdbrownaia in Thread: Paint Materials Testing - Light Spots
    2.86%
    1
    Post #23989 by mdradvies in Thread: Align sweeps in 3D
    2.86%
    1
    Post #23769 by mark b in Thread: I hate roofs
    14.29%
    5
    Post #23536 by mdradvies in Thread: Nothing Special, just some 2012 "Detailing"
    5.71%
    2
    August 16, 2011, 04:19 PM
  • Please Vote for the Best 3 Posts of the Month of June 2011
    Oops, this thread was supposed to be posted on July 15th, but I was on vacation, as you can see:
    So, better late than...
    Post #21383 by mdradvies in Thread: equality coolness
    15.63%
    5
    Post #20844 by Munkholm in Thread: Revit and Camera Match / FOV and Focal Length
    15.63%
    5
    Post #20055 by Alfredo Medina in Thread: Nested Components problem - fresh eyes needed!
    3.13%
    1
    Post #21677 by Alfredo Medina in Thread: x-y Annotations
    0.00%
    0
    Post #21256 by mark b in Thread: Picket Fence by Beam System
    28.13%
    9
    Post #21076 by JeffreyMcGrew in Thread: Rendering in Revit VS. Other Platforms: ...
    9.38%
    3
    Post #21064 by Munkholm in Thread: 2011 - Visibility Controls
    15.63%
    5
    Post #20639 by jaypolding in Thread: Geometry barely visible in sketch mode (RAC 2012)
    0.00%
    0
    Post #19869 by need4mospd in Thread: Section Line Symbol
    6.25%
    2
    Post #19806 by Munkholm in Thread: Aligning radius
    6.25%
    2
    July 19, 2011, 04:37 PM
