What Revit Wants: Getting Started with Autodesk Forge – The Easy Way
    As you probably know, Forge is kind of like Autodesk’s way of opening up a model API for anything and anybody to connect to (over-simplified description, I know).
    If you do want to start playing with Forge, Philippe Leefsma has put together a whole lot of boilerplate code that you can deploy on Heroku. He has shared a collection of node.js-based boiler projects for the Autodesk Forge Web Services APIs.
    The main page includes step-by-step workflows on how to get started, deploy the code, and test the framework:
    Check it out at:
    The post Getting Started with Autodesk Forge – The Easy Way appeared first on What Revit Wants.
    Author of What Revit Wants
