Revit OpEd: Mastering Autodesk Navisworks 2012
    As I just wrote about Navisworks concepts yesterday. I should mention a great new source of information on the product. Wiley/Sybex just published the hard work of two Autodesk Navisworks guys, Jason Dodds and Scott Johnson. Naturally there is a host of people involved in getting a book finished but the guy they relied on to check their claims and recommendations is Michael Smith, their technical editor.
    Jason has been supporting Navisworks for many years as well as in his current role as Autodesk Construction Solutions Engineer. Scott also toils at Autodesk, he's a Senior Technical Account Manager. These guys both get called in to make things work. Michael works for C.W. Driver as their BIM Manager in Pasadena, CA. These three together provide the necessary depth to get a book like this finished.
    Navisworks can be learned pretty quickly, but it takes some time behind the wheel to really master it. As with anything you tend to learn enough to get by and probably don't really dig deeper. This book provides practical examples throughout in "Real World Scenarios" (a part of the Wiley/Sybex Mastering series format).
    There is no shortage of settings in Navisworks and fortunately the guys took enough time to dig into even some of the more arcane stuff, with an eye toward what you are likely to need most of the time. For example in Chapter 4 there is a bit more than page dedicated to the subtlety of exporting from Revit with one option checked or not (Convert element Properties). Unchecked there are six properties exported and checked there are 18...that's just for a roof element.
    You can read the Table of Contents and there are three sample chapter excerpts in PDF format; Chapter 2, Chapter 3 and Chapter 4. It's also available as a EPUB E-Book and Adobe E-Book. Here's the table of contents so you can review it directly. There's 456 pages from inside the cover to the back, including the index etc.
    Table of Contents
    • Chapter 1: Getting to know Navisworks.Chapter 2: Bringing it all together: Files and File Types.Chapter 3: Moving around the Model.Chapter 4: Climbing the Selection Tree.Chapter 5: Model Snap Shots: Sections, Viewpoints and Animations.Chapter 6: Documenting Projects.Chapter 7: 4D Sequencing with TimeLiner.Chapter 8: Clash Detection.Chapter 9: Creating Visualizations with Navisworks.Chapter 10: Animating Objects.Chapter 11: Give Objects Life and Action with Scripter.Chapter 12: Collaborating Outside of Navisworks.Chapter 13: Other Useful Navisworks Tools.
    Some other Links
    Book Description
    Author Information
    Supporting Files
    If you are a Navisworks person you'll probably want this in your collection, check it out!!
