What Revit Wants: Fix OneNote Screen Clipping Keyboard Shortcut
    I experienced an issue where some Windows 10 updates broke my favourite screen clipping tool, OneNote. Typically I’m using it all day long with the Winkey+Shift+S shortcut to send screenshots to OneNote. Is yours broken too, perhaps by Windows replacing it with the built in clipping tool? Here’s how I fixed mine:
    Disable the Global Windows + S Shortcut Key
    Another workaround is to disable the global shortcut key Windows + S. Follow this how-to article or make the registry changes using command line:
    1. Press the Windows key + X to open the WinX menu, and then click “Command Prompt” or “Windows PowerShell“.
    2. Copy the following command and then paste it into the command line. Press Enter.
      reg.exe add HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced /v DisabledHotkeys /t REG_SZ /d S /f
    3. Reboot your computer and OneNote screen clipping shortcut key should resume to work.
    from The post Fix OneNote Screen Clipping Keyboard Shortcut appeared first on What Revit Wants.
    Author of What Revit Wants
