What Revit Wants: Free Tool To Batch Upload Documents to Aconex
    Aconex is a CDE (common data environment) used a lot through some regions for managing AEC correspondence. It is also used to register and share some BIM-related files and documents, although I don’t personally think Aconex is a great tool for that particular job.
    In any case, if you are using it regularly it makes sense to automate the process. RTV have built a tool that allows you to connect with Aconex, and publish and transmit documents through the official register.
    You can get it here: Just fill out the form and checkout, and you will get a link in an email. The current version is RTV Aconex Uploader 2017. You will be able to activate the software for free.
    The post Free Tool To Batch Upload Documents to Aconex appeared first on What Revit Wants.
    Author of What Revit Wants
