Revit OpEd: Revit 2018 - Insert Ribbon Search Field is Removed
    When Autodesk Seek gave up on their mission and handed it over to BIM Object Revit 2017 started to redirect us to that site instead whenever we did a search. Prior to that it would take us to Autodesk Seek.
    Notice anything missing from the 2018 Insert Ribbon image above? Well the post title gave it away but the search field has been stripped off. Remember this following image from way back when?
    I realize it didn't make sense to leave references to Autodesk Seek in play. Now it's even less helpful to find external content. I guess it's more incentive to install BIM Object's Revit app? Probably what they intended.
    No you're not imagining things, it's gone gone gone...
    -- EDITED 5/2/2017 --
    I installed the BIM Object Revit app.
    Holy smokes that's a heck of a ribbon for the primary button I really want, Browse on the far left. Note if you launch any of the tools you can't do any work back in Revit until you finish interacting with their app. If you find that frustrating you could just open a separate browser.
    It would be nice if there were some user settings to reduce the number of buttons to just those you're likely to use. I added the browse button to the QAT to get around accessing the ribbon tab each time.
