Building Coder: RVT Properties to XLS and Forge Accelerators
    Are you interested in easy access to your Revit model properties?Well, you can have that even without a need to install Revit.The Forge Model Derivative API extracts a streamlined copy of all geometry, BIM element hierarchy and properties from over fifty file formats, and Revit RVT files are just one of them.Augusto Goncalves implemented a Forge sample to read all the properties on all BIM elements in an RVT file and export them to an XLSX spreadsheet Test run it yourself Source code on GitHub...
