Revit OpEd: Curtain Wall Panel - Edit in Place
    Here'a a quick post. You can edit a system panel in place. Yes that means you can select a curtain wall's system panel like Glass or Solid and then Edit-in-Place. Do you have a quirky design situation somewhere on your curtain wall and want to just make the change right there without creating a new panel family and loading and swapping? You can!
    • Select the panel (unpin if defined by the CW type)
    • Click Edit in Place
    • You'll find you are in Sketch Mode
    • Select and edit the solid form for glass/solid or
    • Create another form/void to design the custom panel
    • Assign Sub-category(ies)
    • Assign Material(s)
    • Finish the modelling
    • Finish the in-place editing
    et Voila!
    Not the right solution for multiple versions of this but when one (or a few) is all you are dealing with, not bad?!
