Revit OpEd: Shared Parameter Utility - Revit SP Writer
    Alan Jackson has made his new Shared Parameter application available. From his blog openRevit:
    ...snip
    This utility is intended to manage shared parameter files for Autodesk Revit platforms. It was written and tested using Excel 2007.
    Features:
    • Import Shared Parameter .txt files
    • Export Shared Parameter .txt files
    • Create New Shared parameters
    • Selective Export from Parameter Library
    • Organize Parameters
    ...snip
    You can DOWNLOAD NOW from his site.
    He followed up the first post with this one too.
    I know this'll probably not get noticed since there already 3 blog catchers talking about the same thing, but I've not had much joy using this. I can happily import and review a SP file, edit, check and export parameters - but Revit doesn't like the output :
      Send me your file. Excel and text. Contact info is on my site.
        moved to other post
        mertens3d
        ...gregory
        mertens3d - 3d architectural rendering
        hatch22
          Check the settings of your txt-output from revit. The standard settings for the delimitor and such are different from what revit requires...
          BTW: openrevit, welcome to the forum. Nice of you to stop by and help out...
